Hello. // firstly sorry, if this doesnt fit to this topic. move it if there is better for this please//
Most of time I am playing through youtube or some local files.
I have Edifier https://www.muziker.com/edifier-2-0-r1600tiii (played through 3,5mm jack in PC -> RCA cable in speakers).
I bought ORAVA Pegasus 2 - https://www.orava.eu/en/wifibt-speaker-pegasus-2, which has WIFI connection
and I would like to have 2x ORAVA pegasus 2 in kitchen and hall connected by wifi to home network and the Edifier connected directly by cable.
Is there any potencial to do this through any of VB-audio software?
I was able to pair ORAVA pegasus 2 through bluetooth, but then there is delay in the sound against the cable connection - which I need the same sound at the moment at all rooms, WIFI connection allows only in MUSO PLAYER, which doesnt support youtube and its not for Windows..
Any advice, how to solve this?
Only possible way was to buy a mix with 3 outputs and have cabels close the walls.. but rather I would use some app..
Thanks for support. Vítek.
How to pair cable and wifi speakers to PC and play?
Re: How to pair cable and wifi speakers to PC and play?
update - noone knows ? please.
you may try Voicemeeter Banana is guess.
So i paired on one wifi the reproductor and the PC.. (DLNA)
so I was able to send the sound through Windows Media Player to DLNA
but when I tried (I tried Potato/Banana..
I added VBAN, IP adress of the speaker as output, put the VBAN ON..in the outputs I putted it as B1 and nothing goes out.
only output was through classic speakers on cabel :/ so I dont know, if I did anything bad..
