No Stream
Posted: Mon Apr 11, 2022 5:20 am
by shofotolagski
VBAN-Receptor The iphone can't connect to the host, but the ipad is available
info won't light up
VBAN receptor version 1.7, ios store Hong Kong, mobile iPhone 6plus model NGAA2CH/A, ios 12.5.5
Software is the latest version
- 屏幕截图 2022-04-07 225513.jpg (76.19 KiB) Viewed 75519 times
- 屏幕截图 2022-04-07 225720.jpg (203.98 KiB) Viewed 75519 times
- 2022-04-08 083951.png (207.04 KiB) Viewed 75519 times
Re: No Stream
Posted: Mon Apr 11, 2022 5:21 am
by shofotolagski
- 2022-04-08 083941.png (227.83 KiB) Viewed 75518 times
- 屏幕截图 2022-04-07 225559.jpg (244.28 KiB) Viewed 75518 times
Re: No Stream
Posted: Mon Apr 11, 2022 5:59 am
note the about / registration dialog box is not useful here,
you may post the Voicemeeter system settings dialog box instead.
apparently your PC 192.168.1.238 does not see your iPhone in 192.168.1.121
could you use the command prompt tool to execute: ping 192.168.1.121 ?
(to check that you PC can see your iPhone).
