When I upgraded from Voicemeeter to Banana, I think I had to re-configure everything from scratch. Now I want to upgrade to Potato - is there a way to save and restore all the settings from Banana - mainly input/output channel assignments, ASIO settings, and such.
It's not a huge amount of work, but it sure would be nice if I didn't have to go through it all again.
Upgrade from Banana to Potato
Re: Upgrade from Banana to Potato
you can save your Banana settings in a file... and then load it after in Potato.
