Recorder Options Help
Posted: Mon Apr 25, 2022 5:38 pm
by nicktherat
I have it set to record at 48k mp3
I can not change the depth to 24? its greyed out
After i record and open the file it is 32k not 48k
works properly with WAV but i do a 4 hour long show and the file would be huge compared to mp3.
Re: Recorder Options Help
Posted: Thu Apr 28, 2022 11:09 am
could you confirm you have the last Voicemeeter version ? what is your number ?
Posted: Thu Apr 28, 2022 3:49 pm
by nicktherat
version 3.0.2.2
I can make a video demonstrating what i am experiencing if you want. its not a HUGE issue because i can just open, convert and export as 48k, but it would be nice if it ....worked properly?
I am also opening the file with audacity, not sure if that would matter.
Posted: Thu Apr 28, 2022 5:49 pm
24 bit does not exist for mp3, but you should be able to set the samplerate to 48kHz...
could you specify the context more precisely?
Posted: Thu Apr 28, 2022 6:13 pm
by nicktherat
sorry for the squished screen (i have an ultrawide) but i think you can still read the important parts (let me know if you cant)
https://youtu.be/0BfJRc2PatM
i record in mp3 at 48k, open in audacity and project rate is set to 32, then i do it for wav and open in audacity and its set properly at 48k
Posted: Sat Apr 30, 2022 9:54 am
maybe the mp3 kbps is too low to keep 48kHz signal in mp3 file.
try 192 kbps instead.
Posted: Sat Apr 30, 2022 7:36 pm
by nicktherat
you are the winner!
