VoicemeeterPro Setup Package Installation and VB-Cable
Posted: Wed Jun 08, 2022 5:58 pm
Hello!
Installing the VoicemeeterPro Setup Package (Version 2.0.6.2) also installs VB-Cable, or does it have to be separately downloaded and installed?
I ask this because I just downloaded and installed the VoicemeeterPro Setup Package in Windows 10, and although I can't see the virtual audio cable installed, I can see its files ("VBCABLE_Setup_x64.exe", etc.) in "C:\Program Files (x86)\VB\Voicemeeter". I can also see some VB-Cable related files in "C:\Program Files\VB\CABLEVM" and "C:\Program Files\VB\CABLEVMAUX" (3 files in each folder).
If VB-Cable has to be manually installed, in spite of what I just described above, should it be installed running "VBCABLE_Setup_x64.exe" from "C:\Program Files (x86)\VB\Voicemeeter", or does it require to be separately downloaded and installed on its own?
Thanks in advance for your help.
