ASIO showing on Banana but not on Potato
j3yps
Post by j3yps »
Hi hope someone can help me sort this one out. I use a Focusrite Scarlett 2i4 interface. I can select it as my ASIO device on Banana, but when i try using Potato it does not appear (it just show a blank option on the lowest part of the A1 output list without any texts that i cant even select) and from the looks of it. All asio "device" arent showing up on Potato (even ASIO4ALL)
I tried the following:
- clean Installing/Uninstalling (reboot whenever needed) both voicemeeter and focusrite drivers
- install only ASIO4ALL and voicemeeter
- install only the Focusrite driver and Voicemeeter
- installing the drivers first before voicemeeter (vice versa)
All latest versions:
Voicemeeter
ASIO4ALL
Focusrite Drivers
Windows 10
Re: ASIO showing on Banana but not on Potato
could you give some information about your banana version and potato version number.
j3yps
Post by j3yps »
Vincent Burel wrote: Sun Jun 26, 2022 6:04 pm could you give some information about your banana version and potato version number.
Banana is 2.0.6.2
Potato is 3.0.2.2
potato x64 or 32 bits?
j3yps
Post by j3yps »
Potato x64, the 32bits isn't launching even after multiple install/reinstall
don't understand why Potato 32bit cannot run... very strange.
so the explanation is
Voicemeeter Banana is 32bit and will list 32bit ASIO interfaces
Voicemeeter Potato 64 bits will list 64bit ASIO interfaces
so maybe you have not installed the 64bit version of your ASIO interface.
j3yps
Post by j3yps »
Vincent Burel wrote: Mon Jun 27, 2022 2:29 pm don't understand why Potato 32bit cannot run... very strange.
Very strange indeed as this is the first time I've encountered this problem with Potato (been using it since release with different interface, including this 1st gen 2i4)
Anyway, was able to "fix" it by reinstalling (clean install) Windows 10
