Multitrack Recording
Posted: Mon Jul 18, 2022 10:19 pm
by number7
I would like to record multiple input channels. I've set post-fader outputs to Bus A2 and set output A2 composite. So far so good.
But even all input channels are muted and not any bus selected for input channels I get an output signal on output A2. Checking all sources I found the webcam microfone as the source.
What is the concept of this when signals are bypassing all settings and I've no option to decide which device should be recorded?
Recording - short glitches
Posted: Mon Jul 18, 2022 11:00 pm
by number7
until now I had only ever taken unimportant recordings using Banana. Now I need a high-quality recording and had to realize that short glitches can be heard regularly when recording via Banana. When recording directly from the microphone, these noises cannot be heard.
Does anyone have experience with high-quality recordings? Where do these short glitches come from and how can you avoid them.
