I'm having MT32-SPLite configuration problems (Estou tendo problemas de configuração do MT32-SPLite)
MT32-Sound Pad Lite
shimatani
Post by shimatani »
Oi, muito obrigado por aceitar aqui no forum, vou escrever em duas linguas english e portuguese e eu tenho algumas perguntas:
  • como configurar corretamente o MT32-SPLite?
  • como gravar entrada de audio pelo vban?
  • quais as placas atuais asio audio em pci ou pci-e são recomendados?
  • qual o monitor lcd touch screen é recomendado?
ao longo das perguntas serem respondidas vou colocando mais.
Obrigado.
In english
Hi, thank you very much for accepting here on the forum, I will write in two languages, english and portuguese and I have some questions:
  • how to correctly configure MT32-SPLite?
  • how to record audio input by vban?
  • which current asio audio pci or pci-e cards are recommended?
  • which lcd touch screen monitor is recommended?
As the questions get answered, I'll add more.
thanks
Re: I'm having MT32-SPLite configuration problems (Estou tendo problemas de configuração do MT32-SPLite)
hello,
1- When starting the MT32-SPLite, you may create your project:
  • Define a name and select a disk to store recorded tracks.
  • Check the sampling rate of the project, then create project.
2- Connect the MT32-SPLite to an ASIO device (use the page selector on bottom right). the MT32SPLite is expected to work with any ASIO device (PCI, USB or other...)
3- Go in TAPE-ARM page to arm track before recording.
4- TOOLS & VBAN page allows to activate and configure VBAN in the MT32-SPLite.
  • You can define / detect up to 8 incoming VBAN Stream and route them to input tracks - to record them
5- Touch Screen must have a minimal resolution of 1024 x 768
more info in installation guide and reference manual:
https://download.vb-audio.com/Download_ ... ide_EN.pdf
https://vb-audio.com/mt128/MT128_ReferenceManual.pdf
