Macrobuttons to control VBAN - works!
stoepie
Post by stoepie »
In the MACRO BUTTONS section of the manual it says it's possible to control all VBAN functions from the macro buttons,
Page 43 of the user manual wrote: On Voicemeeter BANANA version, it is also possible to:
- Make voice FX by changing Modulation and Color Panel.
- Launch Sound by the integrated audio player
- Make special correction with the bus parametric EQ
- Remote all VBAN functions
but I am unable to get that working.
Wasn't sure if this needed to go under VBAN or Voicemeeter, please do move the topic if needed.
Any hints would be appreciated.
Cheers,
David
stoepie
Re: Macrobuttons to control VBAN
Post by stoepie »
Found it.... makes sense too, just wasn't what I excpected :mrgreen:
I tried "vban.instream.on" and "vban.instream.off", but that is not what the manual says.
It has to be "vban.instream.on=1" and "vban.instream.on=0", respectively.
Reading can be difficult :roll:
