I have the problem that there is a clicking noise at the beginning in some samples when using VB Audio Cable in FL Studio.
I route the MIDI and audio signal from FL Studio into an app to record samples. Basically, the app presses the note via MIDI and uses VB Audio Cable audio driver to grab the audio signal to record an instrument sample/note.
But out of about 20 samples, a short clicking sound can be heard in 2-3 samples at the beginning and I've tried all sorts of audio settings and troubleshooting, but without success. When I downloaded a demo version of Studio One 6 and tried it, there were absolutely no clicking sounds.
So is the problem really with FL Studio or maybe something else could be an issue?
Clicking noises in FL Studio
Migma
- Clicking sound 2 compressed.zip
- (495.17 KiB) Downloaded 1010 times
- Clicking sound compressed.zip
- (202.92 KiB) Downloaded 972 times
Migma
Re: Clicking noises in FL Studio
Issue solved. The clicking noises disappear when you select the FL Studio ASIO driver and then select VB Audio Cable as input and output in the ASIO settings.
