Voicemeeter Startup
Posted: Sun Feb 05, 2023 10:03 am
by JazzCafe
The 'Show App on Startup' option does not seem to work. If I unselect it, it continues to show on startup. Any ideas?
Thanks.
Voicemeeter Banana 2.0.6.8
Windows 11 Pro
Re: Voicemeeter Startup
Posted: Sun Feb 05, 2023 11:16 am
maybe because you did not activate the option show in systray , could you post your Voicemeeter menu screenshot ?
Posted: Sun Feb 05, 2023 11:36 am
by JazzCafe
I don't really want it in the systray but I would like it to startup minimised to the taskbar if possible.
Posted: Thu Feb 09, 2023 10:12 am
if not in System Tray and launched without showing the APP.
how could you be able to show it ?
Posted: Thu Feb 09, 2023 6:53 pm
by JazzCafe
Once it's launched it shows up on the Taskbar (Minimised) you can then click it to view it when needed.
Posted: Fri Feb 10, 2023 8:51 am
ok, i note that !
