VBCable Driver Errors
crummei
Post by crummei »
I'm getting issues with VBCable B installation, it's giving me errors constantly, it was initially having errors with VBCAble, VBCable A and VBCable B, but I fixed VBCable and VBCable A.
I tried fixing VBCable B the same way I fixed the others, but it didn't work, I uninstalled, rebooted, installed, and rebooted multiple times, but nothing happened after I uninstall and rebooted I decided to try and go into device manager and remove any VBCable B related things I could find, then install and reboot, this also did not work.
The error I'm getting is
CHECKING VB-Audio Cable B (version 01000305)
*ERROR MME Output - Bad Pin Name: Cable B Input (VB-Audio Cable B
*ERROR MME Output - Bad Pin Icon: %windir%\system32\mmres.dll,-3010
*ERROR WDM Output - Bad Pin Name: Cable B Input (VB-Audio Cable B)
*ERROR WDM Output - Bad Pin Icon: %windir%\system32\mmres.dll,-3010
*ERROR TOTAL FOUND: 4
Re: VBCable Driver Errors
for this problem, all solutions are given in first thread of this forum:
viewtopic.php?f=7&t=688
