VoiceMeeter constantly using 36% - 40% CPU
Posted: Thu Jun 15, 2023 1:56 am
Hello!
Recently, I noticed VM constantly has very high CPU power usage. I do not know when it started nor can I link a specific event to it. I searched through the forum and found this - among other things - and followed the instructions exactly. Doing so did solve any driver errors found using the driver diagnostic tool, but did not affect the high CPU usage.
Any advice on further steps to troubleshoot the issue would be much appreciated.
Thanks!
-Adam
EDIT: A couple points worth noting. . .
Thanks!
-Adam
- I originally had the VB Cable Driver Packs (A & B) installed, but have since uninstalled them to help narrow down the possible culprit/s.
- Even after following the steps in the link above (including all reboots), all of the settings were restored when I reinstalled VM. Could it be that whatever is causing the high CPU usage is not being uninstalled/removed during the uninstall process?
