Good evening.
I am using vb hi-fi cable to stream music from my streaming platform to Jplay. I am using the biggest possible latency on vb hi-fi cable, to support the lowest possible dac link value on Jplay. I have noticed that lowering dac link value on Jplay improves SQ in my system but there is a limit at 2,5hz dac link value. Lowering the value more, is not possible as the max latency value on vb hi-fi cable is not sufficient to support it. Is there any way to further increase maximum latency on vb hi-fi cable? Is there any other option to make my system work with lower dac link value on Jplay (I would like to reach 1hz).
More max latency needed to fully support jplay
Periklis
