Matrix Crashes reported at Cantabile forum
Posted: Sat Oct 21, 2023 4:57 pm
by Ade
Vincent, there was quite a lot of interest in Matrix over at the Cantabile forum. The initial tests were producing crashes.
Please check this out- thanks!
https://community.cantabilesoftware.com ... atrix/9041
Re: Matrix Crashes reported at Cantabile forum
Posted: Sun Oct 22, 2023 6:10 am
Thanks for reporting, our different Virtual ASIO driver (32 or 64bits) are expected to be validated, meaning it should work with any applications... and this is apparently the case, except with cakewalk in undefined conditions (this has been already reported).
But since it is the only issue report about our VASIO, i would recommend to report the problem to Cakewalk guy first. Then, if cakewalk guy cannot find the problem on their side, i will take a look on this case.
Solved! Matrix Crashes reported at Cantabile forum
Posted: Mon Oct 23, 2023 7:56 pm
by Ade
I'm pleased to let you know I was able to get a very good result with Cubase and Cantabile which has been posted back at the same thread on the Cantabile Forum.
Thanks for your feedaback!
Posted: Tue Oct 24, 2023 7:27 am
Good to know, thanks for reporting!
