"Fill/Repeat" 7.1 to All Channels? This is for DuelSense Haptics.
audioj75
Post by audioj75 »
I'm using VM Input (Banana) configured as a 7.1 system. On one of the outputs (DuelSense Controller), I'd like to mix all incoming channels to all the output channels (or 2 specific ones if possible - the controller show up as a 4 channel, and the rear two channels are the haptics). "Stereo Repeat" only copies L/R to all channels. Is there a way to have "All Repeat"? Composite only let's me patch channels 1:1.
I have a hacky solution, but this introduced a substantial delay.
  • From B1 (Voicemeeter) Input, output to B1 with Mix down.
    In sound settings, set B1 (Voicemeeter Output) to Listen on Voicemeeter Aux Input (B2).
    Set B2 to output to device of choice, and Stereo Repeat.
I wish there was a way to do the "Mix down" AND "Stereo repeat" in one step. Is there a better way?
