Is it possible to periodically check availability of the device master?
I have my console plugged in but it is turned off at night. When my PC boots in the morning (before I am awake), Matrix recognized the device master is absent.
However, later, when I turn the console on, Matrix does not attempt to connect again.
Is it possible to set a periodic check if the device master is available? If available, connect and restart the service. Otherwise, do nothing.
Auto-reconnect device master
Re: Auto-reconnect device master
yes, we can add an option to restart audio engine when the Master device is not running , like in Voicemeeter.
BRCook
Awesome, thank you!
