Hi members,
it appears that the custom configuration for Potato is stored somewhere in a user's profile. I would like to automate the start-up configuration for each user logging in to the computer.
At the moment, each user has to initially launch Potato which loads the default interface without any routing etc. then they select their preferences and link the configuration file to load at start up.
If a user's profile resets, this process is gone and needs to be done again.
Does someone know where I can change this behaviour and load the correct configuration no matter if a user has used potato on the machine before or not?
Thank you very much in advance.
Potato default configuration
Re: Potato default configuration
Hi, I've been working on a CLI program which may be able to help you.
https://github.com/onyx-and-iris/vmrcli
With it you can load a specific kind of Voicemeeter GUI, load a specific user configuration + other good stuff.
I've added a compiled binary to Releases if you're unsure how to build.
