New Voicemeeter 2.1.1.3 Stops Working after Hibernate Resume
audioj75
I installed the new Voicemeeter Banana, and audio stops working after some hibernate resumes, seemingly needing a reboot. "Restart Audio Engine" does not fix it. I found a work around, which requires the Voicemeeter Input to be disabled and enabled to get audio to work again. Is this a know issue?
Re: New Voicemeeter 2.1.1.3 Stops Working after Hibernate Resume
no, it's not a known issue, and is surely more pending on your device...
normally Voicemeeter restarts on wakeup. If some device are not running, a simple Restart audio Engine should be enough.
to be more investigated...
audioj75
A restart audio engine doesn't do fix it. The only think that works consistently is to disable/enable "Voicemeeter Input" (without even needing to restart audio engine).
You may now try version 2.1.1.8
