Best settings to reduce CPU consumption
Posted: Tue Oct 08, 2024 7:27 pm
Hello Everyone !
I'm trying to interface a Dante virtual Soundcard (could be asio or WDM) with a physical ASIO souncard.
Both of them are synchronized (Using a Dante AVIO AES3 into an AES3 Sync input in the soundcard).
I'm trying to transfer 24 channels in one direction (Physical to dante soundcard), maybe 4 in the other.
When I try that, even if it runs well most of the time, I have sometimes a CPU usage peaks that translate by an audio glitch.
If I want to optimise my settings to reduce the load on the computer, what parameters could I leverage ?
I precise that latency is not an issue, it's for a radio broadcasting.
Do you have any ideas ?
Best,
tellierflexus
Best,
tellierflexus
