Ordinary voicemeeter installed on windows 7 does not receive from other voicemeeter.
I made all the settings and I don't receive the audio from the first voicemeeter, I have 3 voicemeeters on the network and they are all configured, one works and the other doesn't.
What can I do to solve this problem images attached
Problem with the VBAN protocol
shimatani
- anydesk00007.png (238.82 KiB) Viewed 13226 times
- Screenshot_8.jpg (150.89 KiB) Viewed 13226 times
shimatani
Re: Problem with the VBAN protocol
Before you can say it's about simple rate, I've also done everything the same and it doesn't work
no it's surely about stream name.
you send a stream called "Stream2" to 192.168.0.52
so you must also called "Stream2" on reception.
TIPS: right click on Stream Name to get the list of incoming stream and select it directly.
