My VOICEMEETER INPUT is the output in my Windows 11.
After reboot it always jumps back to an other device, even if VB is selected as DEFAULT.
Is there an option to force VB taking over the windows device ?
Else I might need to script it.
windows audio jumps to default on startup
- Contact:
Re: windows audio jumps to default on startup
Have you saved settings then load settings then load settings on startup?
