VBAN Receptor Audio Routing Issues
CravenInsomniac
Post by CravenInsomniac »
Hi all,
I have the full Android VBAN Receptor app and I'm having issues with it only outputting to my phone's speaker on Android 15. My phone and app information is below.
Model: Google Pixel 9
Android Version: 15 (Build AP4A.241205.013)
VBAN Receptor Version: v1.9.1 (Build 43)
So far I have:
  1. Tried using wired and Bluetooth headphones
  2. Uninstalled and reinstalled the app.
  3. Power cycled the device.
  4. Tested with 48 kHz and 44.1 kHz sample rates.
  5. Tested with every format and network quality.
A couple things I noticed:
  • The throbber just spins when I try to manually route the audio from "This phone" to "Wired headphone" via the notification.
  • When pausing the stream, the notification shows that it does switch from "This phone" to "Wired headphone" in the notification. But it switches back when you resume the stream.
Any ideas would be greatly appreciated.
Re: VBAN Receptor Audio Routing Issues
We must buy an android 15 device to check what's happening...
