Having to reset voicemeeter daily because garbled sound on mic.
Malic
Post by Malic »
I am using a two PC setup for live streaming. I have my microphone ran to the primary PC that Voicemeeter is on for OBS capture, and it uses VBAN to send it over the network to my Game PC, so I can then use it for Discord voice calls, ect on that computer.
The issue that started a few months ago is that the mic output, overnight just turns into a high pitched garbled mess the next day. It did not used to do this. I am having to restart to fix the sound, and it breaks overnight.
I do not believe it is VBAN causing the issue, as even OBS is just hearing the garbled sound as well until VM is restarted.
Trying to figure out what would be causing this? It has been going on for a while, is just has got to the point that it is annoying now.
Re: Having to reset voicemeeter daily because garbled sound on mic.
you may try to use ASIO driver of your Pro FX instead of using windows audio interface.
see our video tutorial on the subject (replace tascam by Mackie): https://youtu.be/35N8hkOy8h4?si=fBKrS9i-R7cmEjbp
