VoiceMeeter missing icon in task bar
Posted: Tue Jan 28, 2025 1:31 pm
by MrKoddy
My VoiceMeeter has missing icon in the task bar and I don't know why. Issue appeared this week. Do you know how to fix it?
https://i.imgur.com/ZzX1aFv.png
Re: VoiceMeeter missing icon in task bar
Posted: Tue Jan 28, 2025 5:58 pm
could you be more precise? what icon? in system tray ? what is your Voicemeeter version ?
Posted: Tue Jan 28, 2025 9:40 pm
by MrKoddy
the icon you have once you run the app or the one you can pin in the task bar
Posted: Wed Jan 29, 2025 7:06 am
what is your voicemeeter version ?
could you post a screenshot ?
Posted: Wed Jan 29, 2025 12:52 pm
by MrKoddy
Banana 2.1.1.3
I didn't update I don't know why it is the only app which lost its taskbar icon
Here an imgur image with my app and task bar
https://imgur.com/a/82RZ3Rx
edit: I updated to latest version still a balnk icon for voicemeeter only in the task bar
Posted: Wed Jan 29, 2025 3:35 pm
well, i've no idea about how it is possible. never heard about before... have to wait for more report on this...
Posted: Wed Jan 29, 2025 9:22 pm
by MrKoddy
I found a solution. I created a shortcut on desktop then opened the app through the desktop's shortcut and my task bar icon was back!
