Streaming individual dolby multichannel audio to specific network IP addresses
DolbyAngel
Post by DolbyAngel »
Hi all,
Looking for some assistance.
I have a Dolby 5.1 file on my computer (Mac or PC).
I also have six network IP audio speakers, each with a unique assigned IP address.
Both my computer and the six IP speakers are connected to our network switch.
I would like to know what is the best way to transmit/stream individual audio channels to the different network speakers (while ensuring lowest latency), for example:
IP Speaker 1 < Receives Left audio channel from computer
IP Speaker 2 < Receives Right audio channel from computer
IP Speaker 3 < Receives Centre audio channel from computer
IP Speaker 4 < Receives Sub audio channel from computer
IP Speaker 5 < Receives Left Surround audio channel from computer
IP Speaker 6 < Receives Right Surround audio channel from computer
These are the specs for the network IP speaker:
Audio Encoding
AAC LC 8/16/32/48 kHz, G.711 PCM 8 kHz, G.726 ADPCM 8 kHz,
Axis µ-law 16 kHz, WAV,
MP3 in mono/stereo from 64 kbps to 320 kbps.
Constant and variable bit rate.
Sampling rate from 8 kHz up to 48 kHz.
Opus
Network Protocols
IPv4/v6b, HTTP, HTTPSc, SSL/TLSd, QoS Layer 3 DiffServ, FTP, SFTP, CIFS/SMB, SMTP, Bonjour, UPnPTM, SNMP v1/v2c/v3 (MIB-II), DNS, DynDNS, NTP, RTSP, RTP, TCP, UDP, IGMPv1/v2/v3, RTCP, ICMP, DHCP, ARP, SOCKS, SSH, NTCIP, SIP
Thank you in advance for your help.
Re: Streaming individual dolby multichannel audio to specific network IP addresses
This question is maybe out of our scope.
we can help only if
- or your speakers are connected to your computer (with an audio interface).
- or your speakers are connected to a VBAN receptor device.
- or your speakers are connected to a something that can be handled as audio interface by your PC.
DolbyAngel
Hello Vincent,
Thank you for your reply.
Can you expand on the VBAN receptor device?
Is it possible in VBAN to manually enter IP address for individual channels of a multitrack file?
We will try to figure out the rest.
Thank you.
