Window flickering occasionally
maby
Post by maby »
I've been a Potato user for a long time and it has been very successful. Recently, the window has started flickering periodically. The application works fine - no audio disruption. It happens pretty much at random - at intervals of a few minutes. The window remains displayed and in the same place on the screen, but various controls simply disappear and are repainted. It's all over in less than a second and all continues to work fine throughout.
The system is Windows 11 on an AMD Ryzen 5700 and all current Windows updates are installed. Voicemeeter is 3.1.1.9 64 bit. I'm running two widescreen monitors connected to an NVIDIA NVS510 graphics card. Nothing - apart from Windows updates - has changed, and Voicemeeter has run fine on this configuration for a long time.
Martin
Re: Window flickering occasionally
this is not a known issue... Sounds more like a video driver problem or general system issue...
maby
Post by maby »
It has only started happening recently and only the Voicemeeter window is affected. I have a video capture that demonstrates it, but it is 2Mb long and exceeds the maximum file size permitted - how can I send it to you?
Martin
