Screensharing Problem with VB-Audio Matrix
Tekkerue
Post by Tekkerue »
Hi all,
I’m trying to get VB-Audio Matrix to play sound from DaVinci Resolve Studio using ASIO over Watch2Gether for screen sharing, but I cannot get it to work. I’ve also tried Zoom but cannot get this to work either.
I’m on Windows 10 Pro and have an Audient iD14 audio interface.
In Matrix, I created a virtual audio cable and routed it to my interface under Windows Device inside of Matrix. In Resolve I selected the virtual cable as my output. In Windows Sound the Audient 1/2 is selected as my default sound device. Here are screenshots of my full setup:
VB-Audio Matrix:
Matrix Setup.png (94.12 KiB) Viewed 230073 times
DaVinci Resolve:
Resolve Setup.png (73.87 KiB) Viewed 230073 times
Windows Sound:
Windows Sound.png (33.97 KiB) Viewed 230073 times
Everything works on my end, I get sound out of Resolve and it plays through the default Windows Device, so it seems like this should work.
However, when I go to Watch2Gether and try to screenshare with audio I get an error:
“The device could not be activated. Please check the permissions by clicking on the lock symbol next to the address bar.”
When I try to connect to Zoom I get an error:
“Failed to detect your speaker. Please make sure your speaker is properly connected.”
If I close Matrix and use “System Audio” as the output in Resolve, then it plays through both Watch2Gether and Zoom. However, due to a bizarre complication with Resolve and an audio plugin (outside of the scope of my question) in order to get the plugin to work I do have to use ASIO as the output from Resolve. So I need to route the ASIO output from Resolve to the system audio and have that work through Watch2Gether or Zoom (if I can get Zoom working then Watch2Gether should also work).
Any help in getting this figured out would be greatly appreciated. Thanks!
Re: Screensharing Problem with VB-Audio Matrix
you may use Matrix VAIOs (and activate the related slot) to manage windows audio.
every audio source should pass into matrix, if you want to manage sound in rational way.
otherwise you may get audio conflict, for example application could not be able to use the device selected in WIN1.OUT slot.
Tekkerue
Post by Tekkerue »
Hi Vincent, thank you for your reply. I tried using the VAIO section in Matrix and I tried selecting all of the VASIO options provided in Resolve (128, 64A, 64B, and 8), but I cannot get any sound at all out of Resolve now. I’m still not sure what I need to do to get this to work.
Here are my new settings using the VAIO section.
Matrix:
Resolve:
Thanks again.
if Resolve is connected to Matrix VASIO 128, you must set it online in matrix (the VASIO 128 slot).
Tekkerue
Post by Tekkerue »
Thank you Vincent. I now get sound out of Resolve, but unfortunately I'm back to the original problem of it not working through Watch2Gether. I can screenshare without audio, but when I try to screenshare with audio I get an error that the device could not be activated. So it appears it is still not seeing it as coming from the Windows audio system.
I'm not sure if I need the VAIO setting, but I left it enabled. Here are my new settings from Matrix and Resolve is set to VB-Matrix VASIO-128:
Thanks again.
You may check what device Watch2Gether is using to capture audio.
if using a Matrix in (Playback device) instead of a Matrix out, you have to check that loopback is activated in Matrix VAIO ControlPanel.
Tekkerue
Post by Tekkerue »
Thank you Vincent. I looked it up and it appears Watch2Gether doesn't have any control over the audio device being used, it is a website and it uses the web browser's audio device. I'm using Chrome for Watch2Gether and Chrome uses Windows' standard audio drivers. After researching in this way, I'm seeing Voicemeeter being recommended instead. I tried Voicemeeter before but couldn't figure out how to get that to work either.
Basically I just need to get audio out of Resolve using ASIO and then routed into Chrome using the standard Windows audio driver. Once it gets to Chrome correctly, then theoretically Watch2Gether will work with that.
Since you are the developer for both applications, would you recommend using Voicemeeter for this instead? Thanks again.
