This morning when I started up, I saw that the AUX1 was missing the equalizer settings. I don't know if anything is going on. Aux2 seems to be working.
The first virtual input is working, I normally don't use that, but one app is using it.
I've attached a picture of the issue
I tried restarting voicementer several times, no change
Thanks in advance
Virtual Input AUX1 missing
linuxgurugamer
- vm.png (43.14 KiB) Viewed 66070 times
ragnar.jensen
linuxgurugamer
Re: Virtual Input AUX1 missing
Thank you, that was the problem.
