Voice Meeter, Camtasia 2024 & Cubase 14 Pro
Posted: Mon Aug 04, 2025 8:00 pm
by RobJames
Gentlemen, I'm writing to you today to seek Support. I'm trying to use Voice Meeter as an audio bridge to create Camtasia video tutorials, inside of Cubase 14. I'm on Win 10, using Camtasia 2024, and Cubase Pro 14.05 with a MOTU 24 I/O Rack Mount Audio Card. My Audio Card has the newest drivers, and my Voice Meeter is also the newest version available. The problem I'm encountering is completely garbled audio. In Cubase 14 I record in 44.1 khz 256 Samples, 32-bit Float point. When I select the Voice Meeter drivers, it tries to force my Audio Card to 48 khz, which as you can imagine messes up the Project I'm trying to show the Tutorial in. I've tried everything I can think of, but can't resolve the issue. When I look, Voice Meeter only sees 48 khz drivers. Is this a known bug? Is there any way to resolve this, or should I be looking at a different audio bridge program to get this working. Or maybe an older version of Voice Meeter that uses 44.1khz drivers is available to try? I'm really stumped here guys, any and all advice offered is appreciated! If you heard the audio, you would be horrified, compared to the pristine sound of Cubase 14.
Rob,
Re: Voice Meeter, Camtasia 2024 & Cubase 14 Pro
Posted: Fri Sep 05, 2025 10:57 am
you may post screenshot of your Voicemeeter and its system settings dialog box.
also explain where Cubase is connected to and (camtasia too).
