Just dropping in to add my congratulations for an incredible piece of virtual software. I am testing out the latest beta 2.04 on a scenario of doing daily voiceovers and at the same time as running an internet station all on the same box. It is working well as I send the Internet Radio portion out on B2 and have a stand alone encoder take it from there while going through B1 with virtual cables and usb for production and other use. Quick question on the cassette player portion. Is there a setting that has it cue up and ready rather than autoplay on load? The reason is it's great to have an extra aux player to play audio on command for purposes. Also is there a tutorial or manual that explains the insert patchbay setup?
Keep up the great work
Cheers
Robert
VoiceMeeter Pro and Internet Radio
Re: VoiceMeeter Pro and Internet Radio
Thanks for your use case feedback !
i note to add an option to "Play file on Load or not"
there is no documentation for the moment (and Voicemeeter banana is always not officially released)
but you can watch this tutorial there about virtual Inserts:
http://youtu.be/pDi0Tn2QxXE?t=6m30s
Wonderful!"Play file on Load or not"
Terry's video was very helpful. Thanks!
Cheers
