VoiceMeeter occasionally loses its mind
Posted: Fri Sep 18, 2015 8:48 pm
by mjgraves
I've had a few occasions where VoiceMeeter Banana suddenly loses it mind. To be more precise, it starts to pass garbled audio.
In both cases I think it was related to the host computer being momentarily busy. If found that a quick "Restart Audio Engine" remedies the problem.
Is there anything that I can do to generate logs or other info that might help define the trouble more specifically?
Thanks,
Michael
Re: VoiceMeeter occasionally loses its mind
Posted: Sat Sep 19, 2015 6:43 am
you are on Windows 10 ? you use latest version (2.0.2.3) ?
Posted: Sun Sep 20, 2015 4:17 pm
by mjgraves
Yes, Windows 10 and the latest VoiceMeeter Banana.
I discovered the issue a couple of weeks ago while running VMB on the same computer as vMix & a Hangout. All audio via USB devices to/from VMB. Whenever I performed a video transition, even a simple cut, in vMix the VMB output stream would go all robotic sounding.
The next week I responded by splitting VMB onto another PC. I used VBAN to buss the audio bidirectionally between the PC running the audio devices and that one running vMix+Hangout.
The same sort of thing happened. It seemed to be related to the host PC becoming momentarily busy corrupting the audio in some way.
Posted: Mon Sep 21, 2015 7:01 am
This problem appeared with this latest version (2.0.2.3) ? I mean you did not get this problem with previous versoin on WIN10 ?
Posted: Mon Sep 21, 2015 3:21 pm
by mjgraves
I can't be certain. I first noticed the problem in late August.
The system suffered hard drive failure in early August. Until then it had been running Windows 7. I spent about a week getting it rebuilt and running a properly activated copy of Windows 10. That process was finished about Aug 17th. Which is when I installed whatever was the current beta.
I suppose that I can roll back on version and see if it happens again.
Michael
Posted: Tue Sep 22, 2015 7:35 am
if you have time you can go back to previous version to see if there is a difference...
but we already have got several reports about stream stability problem under WIN10...
Posted: Mon Oct 19, 2015 6:05 pm
by mjgraves
Does today's release of VB-Cable address the stream stability issue you mentioned here?
Posted: Mon Oct 19, 2015 6:23 pm
mjgraves wrote:Does today's release of VB-Cable address the stream stability issue you mentioned here?
not specifically, we are currently validating Voicemeeter on WIN10... will see...
