20% difference in volume between A and B busses
Posted: Sat Jan 23, 2016 11:43 pm
by dudefromthetubes
I followed these instructions linked on Google+ to set up Voicemeeter Banana:
https://plus.google.com/110557338955940 ... tsB3WfMPk8
The sounds route as expected, and I adjust the levels to a comfortable volume on any of the A busses. When I test the B busses (for Skype, Discord, Teamspeak, or OBS) the volume is about 20% lower than the A.
I have tried using a different sound card (I have an onboard and a discrete card), removing drivers, reinstalling Voicemeeter Banana, and the cables, set communication options to "do nothing," and zeroed out all input/output levels in windows.
Happy to provide any screenshots, or perform any other troubleshooting steps to resolve the issue, and document accordingly.
Additional Information:
Windows 7 64-bit
Voicemeeter Banana 2.0.2.6
Realtek onboard sound card
Creative SoundBlaster Audigy 5.1 sound card
Re: 20% difference in volume between A and B busses
Posted: Sun Jan 24, 2016 12:29 pm
if you have checked windows mixer gain and communication option, i don't see what could be the problem except that you have really 20% less volume in BUS B. What are saying BUS level in Voicemeeter ? are they on same dB level ?
