Hi Vincent,
Many, many thanks for this excellent VoiceMeeter Banana!
It is one of a kind, fantastic software.
But, there is just one more thing it is missing though: multi-channel ASIO output.
Right now, there is patching of ASIO inputs, but not outputs.
I have a 4 channel Centrance ASIO device where channels 1/2 are routed to my headphones and channels 3/4 to my speakers, but right now, when I switch to ASIO output, I can listen to VoiceMeeter only through my headphones and there is no way for me to switch the output to my speakers.
Also, if you would consider expanding VoiceMeeter Banana to support multichannel ASIO output, it would be nice if user could set output A1 to ASIO, but then, also, output A2 to same ASIO but different channels. Right now, ASIO is available only on A1, while A2 and A3 can't use ASIO. I understand why it is designed like this, but with multi-channel ASIO output support, it would be really desirable to have possibility to push A2 and A3 to same ASIO device as A1.
Thank you.
Feature Request: support multi-channel ASIO output
Re: Feature Request: support multi-channel ASIO output
thanks for your message,
your request sounds logical, and we already got it from different users...
but you maybe gave the right idea to include this feature in the system settings dialog box...
A bit like we did for physical inputs.
if no device is selected on output A2 or A3 we could display and ASIO PATCH interface to
propose to route them to possible channel of A1 ASIO (if ASIO selected as output A1)...
well, i'm going to think about...
Yes, exactly.
Apply the same logic and user interface of ASIO inputs to ASIO outputs.
Thank you.
Keep up the good work!
Cheers!
Thank you.
Cheers!
Yes, yes, I see it implemented.
This is awesome!
Great job Vincent!
Thank you very much for this.
In my humble opinion, Voicemeeter Banana is now complete.
Everything works as expected, everything is reachable, everything is possible.
Fantastic!
This is awesome!
Great job Vincent!
Fantastic!
yes, right ! we did it on latest version...
thanks for your message!
