Hook Volume Controls to Outputs other than A1
Posted: Tue Aug 30, 2016 2:07 am
Been using voicemeeter banana for about a week now. Works perfectly for my home pc setup.
The one thing I wanted to do however, is use my keyboard volume controls for an output other than A1 and to be able to set it programmatically (i.e. Macro Buttons)
In my current config, I have a macro that switches both virtual inputs between my A1 (headphones) and A2 (speakers) outputs, which I use very often. Right now I have "Hook Volume Keys (For Level Output A1)" enabled. That's great when I'm using the headphones, but changing speaker volume is a bit of a pain.
Is there any plan to expand volume key binding/hooking to the other outputs?
