I use VM Banana on Windows 10 64-bit and I have recently upgraded to version 2.0.3.1.
I have noticed that, although I have set it like that in the menu, Banana refuses to Run at Startup and I always have to start it by hand.
Has anyone else reported anything similar, and, more importantly, is there a cure?
Thank you in advance.
No Autostart in latest Banana
Re: No Autostart in latest Banana
hello,
this is not a usual bug report, i guess there is a simple mistake somewhere.
1- uncheck and re-check "run on startup" option in Voicemeeter Menu.
2- check your startup menu contents.
let us know...
let us know...
i haven't this problem.
If the Vincent's solution doesn't work and as a workaround you can add the voicemeeterpro.exe shortcut inside your startup folder:
- Windows + R keys
- Put this on the field: shell:startup then OK
- Put your shortcut inside the folder.
The other solution is to setting a scheduled task.
Hope this help,
Heavenlot
- Windows + R keys
Hope this help,
Heavenlot
