Manual restart of audio engine necessary after every wakup from sleep
Posted: Thu Dec 15, 2016 10:04 pm
I'm using Voicemeeter 1.0.5.1 with W10 x64. After my pc wake up from sleep (I do not use hybernation) Voicemeeter is still open, but as the audio is not working I need to select everytime "Restart audio engine":
Any solution for that?
EDIT: My problem is part of this problem:
http://vbaudio.jcedeveloppement.com/for ... ?f=6&t=403
As Voicemeeter blocks sleep mode the monitors switches off and after waking up the audio engine fails. But if I enter sleep mode manually and wake up from that the audio engine restarts on its own. So it must be connected with the sleep blocking.
