[Issue][MB 1.0.1.2] initial State with Sendmidi
heavenlot
Post by heavenlot »
Using the Macro Button Version: 1.0.1.2 / Banana 2.0.3.3
Tried on akai LPD8 (which needs to delay the request) & Korg Nanokontrol2.
Depending on the screen attached, the mute strip works but not the sysem.sendmidi on the initial state.
Initial state: Mute sent to Voicemeeter, sendmidi not (off instead of on).
Request button ON: Mute Sent to Voicemeeter, Sendmidi sent (button lit)
Request button OFF: Unmute sent to the Voicemeeter, Sendmidi sent (button off)
Attempted to close the macro buttons and open a new instance of macro buttons.
Where can be the problem?
cordially
Heavenlot.
Re: [Issue][MB 1.0.1.2] initial State with Sendmidi
ok, i see the problem, MIDI output device was not started at right time...
it should be corrected in this new version 1.0.1.4 of MacroButtons:
http://vbaudio.jcedeveloppement.com/Dow ... _v1014.zip
just UNZIP and copy it in your C:/Program File (x86)/VB/ Voicemeeter directory
let us know...
heavenlot
Post by heavenlot »
Hi Vincent,
Thank you for this quick update!
Macro Buttons V1.0.1.4 fix the issue. Perfect! =)
