I have two sound devices; USB headphones and motherboard sound card. I also talk a lot on Skype, vPilot (a flightsim voice program) and Teamspeak. I also want the ability to send audio to other machines, or pull audio from other machines to be heard through my primary sound output. So this isn't just a simple mic+speakers setup.
I also make use of an external program called EndPointController so I can change the default sound device for Windows. You'll need to download this and change the code in the relevant buttons (PowerOff or Toggle) to where you install this application if you wish to use these functions. In addition, devices will switch around when you upgrade VoiceMeeter or other sound drivers, so you'll need to keep an eye on what devices get set by EndPointController and adjust the relevant buttons to suit. If you don't wish to use this application, then reassign the relevant buttons.
Inputs:
- S0 Line In
- on my machine, this comes from motherboard LineIn.
- used for tape players, CDROM players or mp3 player outputs.
- S1 Microphone
- currently using the one on my USB headset.
- S2 CABLE-A
- for Skype/Teamspeak return audio.
- Any CABLE-OUT (including the one bundled with Banana) will do here,
as long as you hook up the other CABLE-IN end to the relevant sound program.
- S3/4 Virtual inputs
- sound output from programs.
- Don't accidentally hook these up to their respective inputs, or things will sound messy.
- pulseaudio
- I normally hook this up to S4, this handles networked sound from other Linux computers.
- I added pulseaudio to my cygwin setup.
- A1 Headphones
- My primary sound output.
- A2 Monitor Speakers
- in my case, motherboard output
- very rarely used, if you heard them you'd understand why.
- A3 VBAN.
- This sends audio out to another machine with VBAN running in receive mode.
- B1 VOIP output
- for vPilot, TeamSpeak and Skype etc. to take as their input.
- B2 Not used (yet)
<?xml version="1.0" encoding="utf-8"?>
<VBAudioVoicemeeterMacroButtonMap>
<MacroButtonConfiguration dx='782' dy='438' />
<MacroButton index='1' type='0' key='43' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_MIDI b1='00' b2='00' b3='00' b4='00' b5='00' b6='00' />
<MB_TRIGGER tchannel='0' tin='-20.0' tout='-20.0' tmsHold='1000' />
<MB_Name>MainVolUp</MB_Name>
<MB_Subname>Volume Up (+2.5db)</MB_Subname>
<MB_InitRequest></MB_InitRequest>
<MB_OnRequest>strip[3].gain+=2.5</MB_OnRequest>
<MB_OffRequest></MB_OffRequest>
</MacroButton>
<MacroButton index='2' type='0' key='46' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>AuxVolUp</MB_Name>
<MB_OnRequest>strip[4].gain+=2.5</MB_OnRequest>
</MacroButton>
<MacroButton index='3' type='1' key='47' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>VOIP</MB_Name>
<MB_Subname>Toggle VOIP</MB_Subname>
<MB_InitRequest>strip[1].Gain=-60
strip[1].Mute=1
strip[1].B1=0
strip[2].Gain=-60
strip[2].Mute=1
bus[3].Gain=-60
bus[3].Mute=1</MB_InitRequest>
<MB_OnRequest>strip[1].Gain=-10
strip[1].Mute=0
strip[1].B1=1
strip[2].Gain=-5
strip[2].Mute=0
bus[3].Gain=0
bus[3].Mute=0</MB_OnRequest>
<MB_OffRequest>strip[1].Gain=-60
strip[1].Mute=1
strip[1].B1=0
strip[2].Gain=-60
strip[2].Mute=1
bus[3].Gain=-60
bus[3].Mute=1</MB_OffRequest>
</MacroButton>
<MacroButton index='4' type='1' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>EQMain</MB_Name>
<MB_Subname>Equ Toggle</MB_Subname>
<MB_InitRequest>Bus[0].EQ.On=0</MB_InitRequest>
<MB_OnRequest>Bus[0].EQ.On=1</MB_OnRequest>
<MB_OffRequest>Bus[0].EQ.On=0</MB_OffRequest>
</MacroButton>
<MacroButton index='5' type='1' key='52' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>Toggle</MB_Name>
<MB_Subname>Toggle default device</MB_Subname>
<MB_OnRequest>System.Execute("C:\Users\defaultuser\bin\AEPC\Release\EndPointController.exe", "", " 3");</MB_OnRequest>
<MB_OffRequest>System.Execute("C:\Users\defaultuser\bin\AEPC\Release\EndPointController.exe", "", " 7");</MB_OffRequest>
</MacroButton>
<MacroButton index='6' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
<MB_Subname></MB_Subname>
<MB_OnRequest></MB_OnRequest>
</MacroButton>
<MacroButton index='7' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='8' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='9' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='10' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='11' type='1' key='42' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>MainMuteVol</MB_Name>
<MB_Subname>Mute Main Volume</MB_Subname>
<MB_OnRequest>Strip[3].mute=1</MB_OnRequest>
<MB_OffRequest>Strip[3].mute=0</MB_OffRequest>
</MacroButton>
<MacroButton index='12' type='1' key='45' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>AuxMuteVol</MB_Name>
<MB_Subname>Mute Volume</MB_Subname>
<MB_OnRequest>strip[4].mute=1</MB_OnRequest>
<MB_OffRequest>strip[4].mute=0</MB_OffRequest>
</MacroButton>
<MacroButton index='13' type='1' key='39' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>NETout</MB_Name>
<MB_Subname>Toggle network audio</MB_Subname>
<MB_InitRequest>vban.Enable=0
vban.outstream[0].on=0
vban.outstream[0].ip="192.168.0.4"
vban.outstream[0].sr=22050
vban.outstream[0].port=6984
vban.outstream[0].name="Netout"
vban.outstream[0].bus=1
Strip[4].A3=0
Bus[2].Gain=-60
Bus[2].Mute=1</MB_InitRequest>
<MB_OnRequest>vban.Enable=1
vban.outstream[0].on=1
Strip[4].A3=1
Bus[2].Gain=0
Bus[2].Mute=0</MB_OnRequest>
<MB_OffRequest>vban.Enable=0
Strip[4].A3=0
Bus[2].Gain=-60
Bus[2].Mute=1</MB_OffRequest>
</MacroButton>
<MacroButton index='14' type='1' key='23' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>Mute Main</MB_Name>
<MB_Subname>Mute Output</MB_Subname>
<MB_InitRequest>bus[0].mute=0</MB_InitRequest>
<MB_OnRequest>bus[0].mute=1</MB_OnRequest>
<MB_OffRequest>bus[0].mute=0</MB_OffRequest>
</MacroButton>
<MacroButton index='15' type='0' key='62' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>Restart</MB_Name>
<MB_Subname>Restart Audio</MB_Subname>
<MB_InitRequest>Command.Restart=0</MB_InitRequest>
<MB_OnRequest>Command.Restart=1</MB_OnRequest>
</MacroButton>
<MacroButton index='16' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='17' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='18' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='19' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='20' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='21' type='0' key='41' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>MainVolDn</MB_Name>
<MB_Subname>Volume Down (-2.5db)</MB_Subname>
<MB_OnRequest>strip[3].gain-=2.5
</MB_OnRequest>
</MacroButton>
<MacroButton index='22' type='0' key='44' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>AuxVolDn</MB_Name>
<MB_OnRequest>strip[4].gain-=2.5</MB_OnRequest>
</MacroButton>
<MacroButton index='23' type='1' key='38' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>LineIn</MB_Name>
<MB_Subname>Input from outside</MB_Subname>
<MB_InitRequest>strip[0].Gain=-60
strip[0].Mute=1
strip[0].A3=0
</MB_InitRequest>
<MB_OnRequest>strip[0].Gain=0
strip[0].Mute=0
strip[0].A3=1
</MB_OnRequest>
<MB_OffRequest>strip[0].Gain=-60
strip[0].Mute=1
strip[0].A3=0
</MB_OffRequest>
</MacroButton>
<MacroButton index='24' type='1' key='40' ctrl='1' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>MuteC</MB_Name>
<MB_Subname>Mute Cable</MB_Subname>
<MB_InitRequest>strip[2].mute=0</MB_InitRequest>
<MB_OnRequest>strip[2].mute=1</MB_OnRequest>
<MB_OffRequest>strip[2].mute=0</MB_OffRequest>
</MacroButton>
<MacroButton index='25' type='1' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name>Power</MB_Name>
<MB_Subname>Deactivate</MB_Subname>
<MB_InitRequest>System.Execute("C:\Users\defaultuser\bin\AEPC\Release\EndPointController.exe", "", " 7");</MB_InitRequest>
<MB_OnRequest>System.Execute("C:\Users\defaultuser\bin\AEPC\Release\EndPointController.exe", "", " 8");
Command.Shutdown=1;</MB_OnRequest>
</MacroButton>
<MacroButton index='26' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='27' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='28' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='29' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='30' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='31' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='32' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='33' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='34' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='35' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='36' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='37' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='38' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='39' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='40' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='41' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='42' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='43' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='44' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='45' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='46' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='47' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='48' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='49' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='50' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='51' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='52' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='53' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='54' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='55' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='56' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='57' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='58' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='59' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='60' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='61' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='62' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='63' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='64' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='65' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='66' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='67' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='68' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='69' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='70' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='71' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='72' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='73' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='74' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='75' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='76' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='77' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='78' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='79' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
<MacroButton index='80' type='0' key='0' ctrl='0' shift='0' alt='0' exclusive='0' trigger='0' >
<MB_Name></MB_Name>
</MacroButton>
</MacroButtonConfiguration>
</VBAudioVoicemeeterMacroButtonMap>
- Volume up/mute/down for S3/S4 input strips for programs to connect to so I can balance sound in 2.5 dB increments.
- VOIP settings (S1 mic, S2 input and B1 output toggles.)
- Outgoing network sound (VBAN).
- Line In toggle.
- Equaliser toggle.
- Mute primary output.
- Mute CABLE-A (a bit superfluous, it just fills a slot here).
- Toggle device for primary output; used so I can connect up pulseaudio to the AUX input.
- Reset buttons for Banana (one to reset engine, one to shut it down altogether).
I hope this is helpful as a start for people to utilise MacroButtons.
Regards, BrickViking (a.k.a. DrSmokey)
