in some cases (e.g. if your application is launched in administrator mode),
Network Mapped Drives could not be listed in MT32-Splite Disk Selector.
(this can happen with right access or when UAC Is enabled for example and more again when running 32bits app on 64 bits O/S).
The solution has been given here by answer.microsoft:
Network mapped drives not available on WIndows 10 TP
https://answers.microsoft.com/en-us/ins ... 178?auth=1
This seems to originally comes from technet.microsoft:
Some Programs Cannot Access Network Locations When UAC Is Enabled
https://technet.microsoft.com/en-us/lib ... s.10).aspx
To configure the EnableLinkedConnections registry value
1- Click Start, type regedit in the Start programs and files box, and then press ENTER.
2- Locate and then right-click the registry subkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System.
3- Point to New, and then click DWORD Value.
4- Type EnableLinkedConnections, and then press ENTER.
5- Right-click EnableLinkedConnections, and then click Modify.
In the Value data box, type 1, and then click OK.
Exit Registry Editor, and then restart the computer.
Network Mapped Drive not visible in Application
