[Feature Request] Macro Button Key Bind (Shift,CTRL,ALT) Modifiers.
mix-man
Post by mix-man »
I would like to assign a key bind to one of the F keys... (IE F11) ... So far this works great except when you hit one of the modifier keys (shift, ctrl, alt) it no longers works.
When using another VOIP app I can assign the F11 key be the PTT. As long as the F11 key is down, regardless of the modifiers, it triggers.
It would be nice to be able to either assign multiple keybinds to a macro button or have the macro button ignore key modifiers if chosen, or both.. :)
Thanks again for the great work!
Re: Macro Button Key Bind (Shift,CTRL,ALT) Modifiers. Possible feature request?
ok, I'm going to think about.
