[Feature Request] Record input for Shortcuts
blue lamb
Post by blue lamb »
Could there be a feature for Voicemeeter.Remote Macro Buttons to record the input button instead of the drop down menu?
For example Razer Synapse can detect which keys you are pressing.
It also adds combinations like Ctrl + Shift and Ctrl + Alt and even differntiates between Right Shift/Alt/Ctrl which makes it possible for combinations like Shift + Right Shift or Ctrl +Right Alt.
Here's an example.
mix-man
Re: [Feature Request] Record input for Shortcuts
Post by mix-man »
This would be an excellent idea!
bugzbunny
Post by bugzbunny »
I'd like this supported too, limited to two keys, is not enough variation to not conflict with other applications :|
yes, we already noted this request...
