Problems with GoToMeeting
Posted: Mon Aug 07, 2017 8:35 pm
Windows 7, 64 bit. SSD, 8G memory. WDM drivers selected.
I have Voicemeeter Banana recently installed and configured as per your recommendations in this post http://vbaudio.jcedeveloppement.com/for ... ?f=6&t=441. Voicemeeter is selected as the default playback and recording device. Skype is working fine. However when I try to use GoToMeeting and select Voicemeeter for mic and speakers I am getting audio disturbances in the test call (Test your Sound) when using the Chrome web app computer audio option or the standalone Gotomeeting client.
https://support.logmeininc.com/gotomeeting/get-ready
Ordinarily without Voicemeeter installed the sound test would work perfectly.
Can you recommend any changes to your recommended configuration to improve the sound quality in this test?
Thanks.
Thanks.
