Need to restart Voicemeeter after wake from sleep/suspend
Posted: Thu Nov 02, 2017 11:23 am
by rv67439
Win7, latest voicemeeter:
after my pc wakes from sleep (a.k. suspend to ram) i have no sound and need to restart Voicemeeter.
- how can i prevent this?
- or else, how can i make voicemeeter auto-restart on wake-from-sleep?
Regards, Ronald
Re: Need to restart Voicemeeter after wake from sleep/suspend
Posted: Sat Nov 04, 2017 8:37 am
normally it should restart automatically...
latest Voicemeeter has now a count down to wait some seconds before restarting audio engine (you should see it since it is displayed on the top right as a progress bar before starting audio) ... this is made to let all system services an devices wake up too... maybe this time is not big enough...
do you restart Voicemeeter with MENU -> Restart audio Engine function ?
Posted: Tue Nov 07, 2017 10:52 pm
by smallfreak
I just want to commit, that this happened to me too. Not after STR but after "hybrid power saving". That is a normal Suspend to RAM, when windows silently makes a dump to disk, just for the case of a power failure during STR. That did happen and so the boot was from disk, but restored the previous session, just as a normal "suspend to disk".
VoiceMeeter Banana (latest) was still in the notification area but totally unresponsive and it did not process audio.
I killed it with task manager and did a fresh start.
It does work after STR for me, that's what I usually do. Recovering from power failure can do other weird things too.
Posted: Mon Nov 13, 2017 12:50 pm
by rv67439
OK, after some more debugging I have the feeling that the Vociemeeter engine is (auto-)restarted after suspend.
But the problem is that the pc is connected to my tv over hdmi and that only after both (tv + pc) are up and running the hdmi connection is initialised. And at this point Voicemeeter is already restarted and does not detect the new hdmi and is thus missing the output to hdmi/tv.
Could this be the case?
Posted: Thu Nov 16, 2017 9:42 am
yes, possibly, if the audio device is not ready Voicemeeter will start without running it...
that's why we added a countdown before restarting...
do you see the progress bar on Voicemeeter when starting it ?
Posted: Fri Jan 31, 2020 9:19 pm
by Clif_Hawk
I could not get VoiceMeeter Banana to correctly load after upgrading to windows 10.
I discover that using the Task Scheduler would allow me to boot VoiceMeeter only if the settings were correct.
Attached are my Task Scheduler XML importable setting created with Windows 10 version 1909 Build 18363,592
Posted: Tue Apr 21, 2020 8:14 pm
by miles267
Hi - have since encountered this same issue with Voicemeeter Banana on a Win10 x64 system. Originally thought it was the Blue Yeti mic device driver. After a series of troubleshooting steps taken, can confirm that's not the case. Rather it's attributed to VM sound engine needing to be restarted manually upon system wake/unlock. Haven't been successfully able to implement the Windows task scheduler hack listed elsewhere. Thanks in advance.
Posted: Tue Apr 28, 2020 8:57 am
by amundsen
Same issue with a MOTU Ultralite under Windows 10 64bit here.
