2.0.3.6 Issues
brickviking
2.0.3.6 Issues
Post by brickviking »
I have two problems, one problem involves the Macro Buttons applications, and the other problem involves Command.Shutdown not working.
The first problem happens when I start up Macro Buttons, it doesn't restore the window size to what it was when I initially saved the macros file. When it does start, it shows the first four buttons in a window that's about 650x180, instead of the 924x436 window with 18 buttons showing. The snippet inside the file shows this size on line 3:
<MacroButtonConfiguration dx="918" dy="426" />
The second problem is: one of my macro buttons is set to emit Command.Shutdown=1 but this doesn't appear to work.
Here's the XML snippet out of my MacroButtonConfig.xml:
	<MacroButton index='26' type='1' key='0' ctrl='0' shift='0' alt='0' anyway='0' exclusive='0' trigger='0' xinput='0'>
		<MB_MIDI b1='00' b2='00' b3='00' b4='00' b5='00' b6='00' />
		<MB_TRIGGER tchannel='0' tin='-20.0' tout='-20.0' tmsHold='1000' tafterMute='0' />
		<MB_XINPUT nctrl='0' nbutton='0' />
		<MB_Name>Power</MB_Name>
		<MB_Subname>Deactivate</MB_Subname>
		<MB_InitRequest>System.Execute("C:\Users\viking\bin\AEPC\Release\EndPointController.exe", "", " 3");</MB_InitRequest>
		<MB_OnRequest>System.Execute("C:\Users\viking\bin\AEPC\Release\EndPointController.exe", "", " 6");
Command.Shutdown=1;</MB_OnRequest>
		<MB_OffRequest>System.Execute("C:\Users\viking\bin\AEPC\Release\EndPointController.exe", "", " 3");</MB_OffRequest>
	</MacroButton>
What other information would you like me to provide?
Regards, BrickViking
(Post 16)
pmueller
Re: 2.0.3.6 Issues
Post by pmueller »
Hello
I can confirm first problem. Window size on Marco Button start isn't correctly set.
Regards,
Patrick
brickviking
Re: 2.0.3.6 Issues
Further to the initial post, I found out that the sequence of buttons I have defined get restored correctly, the only thing that doesn't get restored is the saved window size. However, if I manually select "Load Button Map" and go choose "MacroButtonsConfiguration.xml" from the user's \Documents\Voicemeeter\ directory, the window size is restored correctly.
(Post 17)
Re: 2.0.3.6 Issues
ok, we note the diaplays size not recalled on MacroButtons startup in fact.
brickviking
Re: 2.0.3.6 Issues
I tried something additional: I put a Command.Load="C:\Users\viking\Documents\Voicemeeter\MacroButtonConfig.xml"; into the initial stanza of the first button. I still only got the initial four buttons when I started up MacroButtons. The window only resizes when I manually load the same file from the window menu. I don't know if this will help further refine where the problem is.
(Post 18)
brickviking
Re: 2.0.3.6 Issues
The 2.0.3.8 release fixed the issue with button window size. I'll post the other bug in a separate thread, as it was getting ignored here.
(Post 19)
