Voicemeeter does not start anymore
Posted: Mon Nov 20, 2017 8:27 am
PROBLEM:
After having worked for months or years, Voicemeeter does not startup anymore.
SOLUTION:
In rare cases, the config file might be corrupted and crashes Voicemeeter on Startup.
Simply DELETE the VoicemeeterDefault.xml in all c:\Users\username\appdata\roaming directory
it will reset your Voicemeeter settings, but will let it run correctly.
