Can't use MacroButtons application
Xopa
Post by Xopa »
Hello, thank you for creating a wounderful piece of software such as Voicemeeter Banana, I have been playing with it for several days and everything seems to work fine EXCEPT macro buttons. Really surprised that there are no complaints on this forum about them yet. I am using latest Windows 10 and here is what I actually see when trying to launch VoicemeeterMacroButtons.exe:
As you can see, program is present in taskbar and Voicemeeter recognize it, however there are no visible windows with buttons.
Compatibility modes and running as administrator haven't given any result. :cry:
How can I make this program work? I can provide you any information that is needed about my system.
Re: Can't use MacroButtons application
in your document\Voicemeeter there is a file named "MacroButtonConfig.xml"
could you edit this TXT file and copy there the first lines like this:
<MacroButtonConfiguration x0='-930' y0='108' dx='650' dy='180' />
Xopa
Post by Xopa »
Vincent Burel wrote:in your document\Voicemeeter there is a file named "MacroButtonConfig.xml"
Thanks a lot!! I replaced
<MacroButtonConfiguration x0='0' y0='0' dx='160' dy='39' />
with your line. Everything is working now. I have dual monitor setup and top-oriented taskbar, maybe that was the problem. Thank you for help!
well, no, i'm going to fix this...
