Yeti Mic to Adobe Audition to VB-Aduio Cable
toledotorpedo
Post by toledotorpedo »
Hello all,
I had Yeti Mic to Adobe Audition to VB-Aduio Cable working for a few months then all of a sudden it just stopped working.
I also have Voicemeter Banana but the audio is going straight to X-Split the streaming tool i use.
I am not sure what to do to get the VB-Aduio cable to pick up the adobe audition volum makes no sense.
I will post a small video to what i am trying to show.
Sorry i am sick and i am pretty loud in my video showing you guys what i need help with.
https://www.youtube.com/watch?v=H2YJxBG ... e=youtu.be
Re: Yeti Mic to Adobe Audition to VB-Aduio Cable
you may recheck your audio configuration:
mean the default audio device selected in Windows control Panel / Sound Dialog box.
and the audio devices selected in all your used application (Audition, XSPIT ...)
You may also take a look on this topic:
viewtopic.php?f=6&t=442
