distorted sound - help
HorNet505
Contact:
Post by HorNet505 »
yeez I don't know how to fix this - I guess my robo-distorted output is due to different resolutions ?
My line is:
VLC player @44.1 out > VB-Voicemeeter VAIO @48 (virt.input)> A1 RME Fireface UCX @48k and A2 Cable-A @48k
VoiceMeeter Virt.ASIO is the source for Spectralissime Analyzer
I also tried this setup:
VLC player @44.1 out > VB-Cable B @44.1 (hardware input 1) > A1 RME Fireface UCX @48k and A2 Cable-A @48k
Cable-A is the source for Spectralissime Analyzer
I also notice that the VoiceMeeter Virtual Input is RED which indicates a mismatch?
I attach a screenshot with all settings and hope someone can point me to the correct setting
Composer, Producer
Cubase, Nuendo
https://ScoringStage.eu
Re: distorted sound - help
yes, the Virtual input (Voicemeeter VAIO) has bad parameters for the current buffering.
Please set it back to default internal latency settings (4096 or 7168 sample)
use VBCABLEControlPanel installed with Voicemeeter.
