The VBAN area of Voicemeeter has an option to export and import the setup. The Net Quality column is not recalled and resets to ‘Optimal’.
Please would you include the user’s preferences for Network Quality in the file.
Thanks !
Recalling stream quality in setup file
Re: Recalling stream quality in setup file
yes, we noted the problem, it will be corrected in the next update...
Ade
Great! Thanks!
